Well you'll violate the national electrical code unless you tie the ground rods into your home's grounding electrode system. If you have positively identified noise on your ground system your idea might help as long as after you have tied in your chassis racks and what not you carry the #6 wire to a metal water pipe or back to the main panel. Also put the ferrite doughnuts on every power cord, mic line, interconnect etc. Every little bit helps.Sonny ReVerb wrote:Only if you use Oxygen Free Copper !!briane wrote:I have discussed the idea of sinking a copper rod outside the studio, putting in 1/4" jacks in he walls, along with alligator clips, and then having a direct ground on the equipment.
Any takers? Anyone have any idea if there would be benefit in this?
BTW the noisiest devices in the house are dimmers and those touch on touch off lamps. Eliminating noise at that source is a PIA. You might try ferrite dougnuts available at Amidon or in worst case Rat Shack.
