Sorry this is not the "Dana build".
 I just finished up a "new" 2 watt build for the Trainwreck Express (for bedroom use). The circuit is based on Cliff's 440 2 watt build but follows more closely Ken Fishers layout of separate power board and preamp board. The main difference between the 2 watter and the true Express is this circuit uses a 6SN7 dual triodes as the main power tube. The power board biases each triode separately. The circuit captures the "clean to mean" characteristics of the 50 watt Express but it has a tighter low end response and a more saturated distortion tone when dimed. (Probably due to overdriving the 6SN7) All the harmonics are there including touch response.
The sound is great but I have an issue with HUM. It gets louder as I increase the volume. I have isolated the hum to the 6.3 VAC filament wires. That said I applied two 40uf caps to each filament lead and referenced them to ground. The hum is gone. In addition I have decided to redo the power section rewiring the heater wires and overall improving the lead dress to the heaters on each tube to further reduce any possiblility of hum.
Question: To apply Electrolytic Caps to the filaments...is this an uncommon practice? How will this affect the tone? What is best practice to elimate hum at the heater leads?
Thanks!
Danny
