Where is a good place to get the perf board, similar or same as used in the TWrecks. I'm not looking for boards with turrets or terminals. Just the board material.
Thanks for your reply.
													Where to get perf board?
						Re: Where to get perf board?
I got mine from Dana, (UR12) Turrets were already installed.  I highly recommend!  Tranny's from Moose are pretty sweet as well. Good luck in your build.
I think if you do a search you will find that TW like board isn't available except the custom stuff that UR12 makes.
									Alex
TheCageWreck and Glaswerks SOD100
Dana is really one of the only places to get it. Unless of course you get lucky at a mom and pop electronics store thats been open since 1933...Like I did this week
13 pieces. woohoo!
Allynmey
 13 pieces. woohoo!
Allynmey
What's the "correct" hole spacing for those cruising the old electronics shops?
Bear
						Bear
If you go by the Mark A's layout of the Rocket the hole spacings are 3/8" which is probably correct or average for old style perf board.
The hole spacing is .265 apart and the hole dia is 3/32
https://tubeamparchive.com/viewtopic.ph ... =perfboard
https://tubeamparchive.com/viewtopic.ph ... perf+board
