presence squeal in express (was: low end oscillation)
Re: presence squeal in express (was: low end oscillation)
Some preamp tubes are more prone to oscillate without a grid stopper than others. Try different tubes in V1 if you choose not to use the grid stopper.
No it's routed around the inside of the chassis away from the power tubes.paulster wrote:The NFB wire going to the presence pot could well be the problem if it's too close to the power tube grid wires, especially running parallel to them.Structo wrote:I'm having the same problem on an amp that I just built.
It's a mongrel 6V6 amp but if I max the volume and the presence I get the squeal too.
It looks pretty close in the photos of the Roe's amp too.
problem disappeared after I reversed the wires on the presence pot and moved the two wires to pin 5 on the el34s a little away from the power supply wire underneat the board
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
