butwhatif wrote:You can also take an 1-1/4" piece of heat shrink tube, dia larger than the dia of the tube, and shrink it onto the top 1/2 of the tube.
So is that what is recommended?billyz wrote:The Heat shrink does not give off any burning smell. It is designed for high heat. Also, I have been using it for years without any problems.
I ended up with Heat shrink on all the preamp tubes and it works as well if not better than O-rings. a fraction of the cost. you can even use BOTH !
To just cover the top half of the tube with the heat shrink tubing?
Do you leave the top of the tube exposed?
I don't suppose you would have a picture of this?
I'm having a hard time visualizing this.
