70w Fender OT
70w Fender OT
Hello everybody,
I´m planning to build a #40 clone soon.
I have this OT from an 80´s Fender 75 combo,
the prim. impedance is 8k8 ,
so I could use the 16 ohm tap with my 8 ohm Altec
for 4k4.I wonder if anyone of you has experience
with this model.
Regards Hanno
with this model.
Regards Hanno
				txbluesboy
Re: 70w Fender OT
8.8K seems awfully high for a seventy watt amp. What output tubes did that amp use?
				txbluesboy
Re: 70w Fender OT
Wow, 139 people have looked at this, but no ones saying anything. I think maybe everyone is scratching their heads, like I am, about that primary impedence. However, if your specs are correct, I think when you use an 8 ohm load on a 16 ohm tap as a permanent connection you should derate the transformer by 50%. It is done all the time though.
						Re: 70w Fender OT
Well thanks,I know it can be done.
I was hoping someone might have tried
these OT´s with a Dumble Clone.
I know this series of late 70´s Fenders
(70w UL) was never really popular,
it sure is some heavy iron though..
Re: 70w Fender OT
Your best bet is to cap off the UL taps and run a regular screen supply with 1k 5w resistors on the screens. The output impedance as already discussed is quite high, so just use the 16 ohm tap.
I've had really good success with older iron, but I've never used one of these. I'll bet it'll sould great.
Re: 70w Fender OT
Hello
I totally rebuilt my Fender 75 to a D-clone and didn't like how that OT sounded so I changed it to 50W fender replacement OT and liked it better. But if you have one you should try it!
Re: 70w Fender OT
8K8 seems really high how does it meter to the center tap or ground?
									My Daughter Build Stone Henge
				Jackie Treehorn
Re: 70w Fender OT
I did the same thing, converted a Fender 75 to HRM/skyline.  Except, I kept it ultralinear, without any global negative feedback, no choke, 100k plate loads on both sides of the Long Tail Pair.  I really like the sound of the amp and that iron.  However, I think the transformer has 8 and 4 ohm outputs, only, and is likely a 4.4k, although I haven't tried to measure it.
						Re: 70w Fender OT
Build a 70's ODS with iron from a UL bandmaster. I liked the UL with NFB  but the guitar player liked no UL with NFB better. I did not determine the primary though.
Decent iron, IMHO. Have fun!
Re: 70w Fender OT
Just seen your post.two tone wrote: the prim. impedance is 8k8 ,
with this model.
No prob to use the OT w/ 2*6L6 as a 4.4K prim w/ 8 ohms load on the 16 ohms secondary, but it might be, that it saturates earlier as usual, because you can regard it as an 'overwound' 4.4K
Larry
Larry's Website now with included Pix's Gallery
						Re: 70w Fender OT
Thank you all,looks like I´ll give it a try,
however it will take some time, I´m going on a
2 month vacation .
I noticed all early Dumble combos came with
an 8 ohm speaker being driven from a 4 ohm tap,
so this mismatch is part of the famous tone...
2 month vacation .
