Trainwreck inspired Amp finished + pics + first recordings
after reading allmost every post in the last few month, i finaly finished my trainwreck inspired amp.
for a start to say, it's my first self build amp and it turned out quite good.
i build it with a ppimv, a fast/grad switch, hammond 1650h ot and a 139v ring pt.
V1, V1 Tung Sol 12ax7
V3 EI 12ax7 Telefunken
V4, V5 EH EL34 Mullard
the cab is a marshall 2061cx with 2 g12h and beamblockers installed
the recording was done only with a sm57
second recording (Intro2) was done with a superlux mic.
v1 tungsram 12ax7
v2 ei 12ax7 telefunken
v3 tung sol 12ax7
v4,v5 mullard el34 xf3
v1 tungsram 12ax7
v3 tung sol 12ax7
						Re: Trainwreck inspired Amp finished + pics + first recordings
Hi!
I've build a 15 W Liverpool (EL84) and like the TT 7025 for V1 a lot. It's a matter of taste though. 5751 might be an option if your not to much into gainy amps.
V1 is most important: check for sound, noise floor/microfonic rattles aso.
I did check several types for V2/3 but currently use JJECC83s (yes!) and they fit the bill for me.
Ciao
Martin
Ciao
Martin
i tried again all my tubes in different combinations...
sounds funny, i ended up with the same tubes as before.
i think for the moment im set.
maybe i should get some nos tungsram or mullards if i find some at a reasonable price?
i saw a set of tungsram and rft at ebay for about 50 euro.
Rimy,
Your amp looks damn nice!
I've read the TT 7025 isn't recommended for modern high-gain amps. It works well for you? Could you describe the tone and gain?
I love the Plexi front by the way!
as i said before, i ended up using the same tubes as from the beginning. V1-V2 tung sol V3 ei telefunken.I've read the TT 7025 isn't recommended for modern high-gain amps. It works well for you? Could you describe the tone and gain?
the tone is hard to describe.
it cleans up very nice when you roll down the volume on the guitar, allmost like a acoustic guitar.
and when you turn it up it goes in the direction of gary moore with the soldano
but with more of a brown sound like the first evh. it has a lot of punch and dynamics.
anyway, i've been playing guitar for more than 30 years now, trying to find my sound since.
i finally found it with this amp! each time i play it, i cant get the grin out of my face.
i'm quite busy at the moment, but as soon as i got some time i will record some clips.
Ralph
added some recordings.
Nice build! Nice playing/licks! Your recordings are quiet. No hiss. Is that a respose of the amp or mix?
Decko
						Decko
- Ron Worley
That first bit is great... really shows what these amps can do.... If that's sloppy, well then... I, err.... suck!
Ron
Gut shots?
Me: Just one more...
I agree. Perfect demo for the amp (which sounds great).Ron Worley wrote:That first bit is great... really shows what these amps can do.... If that's sloppy, well then... I, err.... suck!
Very cool all 'round, Ralph.  Congrats on a successful build!
I'll be curious to learn what setting of the fast/gradual you prefer and whether you use the switch once you settle down with the amp.
What guitar(s) do you favor?
decko
its a straight recording cab-sm57-lexicon soundcard-cubase.
no adjustments, only a very little reverb added.
zippy
i use the fast / grad only when i play some songs where i need a clean strat sound. the settings stay the same. vol on 1 o'clock the rest is at 12.
bright switch on 1 with the strat and on 2 with the les paul.
my favorite guitars are the ones i am playing:
gibson les paul standard faded with old paf's
fender strat somewhere 80's with texas special
and a selfbuild bluesmaster i build about 4 jears ago
ralph
zippy
ralph
Klasse, Rimy!
Ciao
Martin
						Ciao
Martin
