124 Layout Revised
Re: 124 Layout Revised
Updated Again!!
T.
T.
Looks like the orange wire to the presence pot got disconnected at both ends.
MPM
MPM
Got it
Here is another, the shell of the bias pot needs a ground wire to V6 pin 8.
Also, indicate that the 6v transformer primaries connect to the fuse and the 'mains' switch (just like the main PT).
"Drive" and "Vol" post should be "Level" and "Ratio."
Wiper of the "Level" pot (currently "Drive") is indicated as V2 pin 7, but should just a letter designation as it actually goes to the 180k grid stopper first, before the pin (which would be pin 2).
There is a jumper wire between the two top poles of the Rock/Jazz switch that should not be there. (ie connecting the paired .01 caps and the 100k resistor).
Now It's Starting to look like a Layout!!
Foot Switch anyone!!!
Tony VVT
Tony VVT
Here are some footswitch pictures.
The first is a presumably Dumble-converted Fender Super Twin switch photographed with an ODS of similar vintage to #124. (Unknown #7, on Rob's picture archive). Clever the way the "EQL" and "DST" label from the original Fender Super Twin matches up with the functions of the ODS.
The second is a my own converted Fender Super Twin two-button pedal like what may have originally been with #124.
The third is one posted by Gil that presumably would follow closely (exactly?) the way Mr. D did it.
You guys are awesome to take the time to do this.
The layout looks great.
Thank you!
Thank you!
- UltraHookedOnPhonix
Gil helped me with the footswitch a while back and here's the layout:
[IMG:931:1024]http://i205.photobucket.com/albums/bb17 ... 24FTSW.jpg[/img]
Thanks everyone for the help!!!!
I've been real busy here lately and will finish it up as soon as I can..
I was thinking it would be really cool if we could have a Dumbleator to match...I see angelodp.. has done a fairly nice layout...as well as Brandon's tutoral and think I have enough info to get started...It would be great to have someone here who has been in a few to moderate the layout and make sure everything stays authentic.. Any takers
Tony VVT Amps
Tony VVT Amps
