Part Sources?
				v00d00blues79
Part Sources?
I'm in the process of sourcing parts for an A1a build and i'm curious where you guys have gotten some of your parts at.  Most specifically:
18.2K resistors
Transformers
160uF/100V Capacitors
Thanks,
Andy
						18.2K resistors
Transformers
Thanks,
Andy
Re: Part Sources?
www.mouser has the resistors and capacitors.
http://www.toneslut.com/transformers/ has the transformers.
HTH,
Ross
HTH,
Ross
				v00d00blues79
Re: Part Sources?
Thanks!
I'll have to look closer at mouser. Didn't notice the caps and resistors there before.
Thanks,
Andy
Thanks,
Andy
Re: Part Sources?
Andy,
Here is a possible part# (Mouser) for the 160uf caps.
661-PH330
I used these in my build and they worked fine. I don't think most people on this forum are too thrilled about using these but they are cheap and are not very large.
Eric
PS: They are rated at 330 VDC
661-PH330
Eric
				v00d00blues79
Re: Part Sources?
What would then be the preferred brand for this cap?  I"m not too worried about the price of the components as it will take me a while to get the parts together anyway, but i'm trying to go for the best sounding amp i can make.
						Re: Part Sources?
You could always try Mallory -- a preferred brand in the real thing. Mouser has one:
539-TCG161T350N2L
damned expensive, though.
						539-TCG161T350N2L
Power supply caps
Mouser either does not have Mallory caps for all the values needed in the power supply or they must be back ordered. What are peoples' opinions on Illinois or Sprague caps? Any effect on the tone, etc.    Thanks.
						Re: Part Sources?
Personally, I don't trust Illinois. They tend not to be overrated like some others and I've seen a couple of tests on various parameters (including ESR, ripple, noise, etc...) and they don't perform as well or last as long as Sprague Atoms.
I've used Atoms pretty religiously for a while now. They test as well as anything not significantly more expensive, and have a good reputation. They retain a nice, low ESR over time, and they tend to be overrated for what they are. Makes me feel more comfortable that they'll last a long time and not fail catastrophically.
I haven't done blind taste tests to see if amps sound better with them in the supply, or anything like that, so take this suggestion with a grain of salt.
Re: Part Sources?
you can get Mallory electrolitic (type TC) and Mallory PVC siginal  caps here  http://www.cde.com/   These are what was used in my real Trainwreck
They have stock. I just placed an order
Re: Part Sources?
Jeffkt-- OK, I'll admit it, I'm feelin' sort of lazy right now, you don't perhaps have the part #'s for the power supply Mallory caps? I'd give my first born for a complete BOM about now.
Oh, did I mention that everyone here Rocks! All my dumbass questions have been curtiously answered.
Thanks guys.
Thanks guys.
				goodtone77
Re: Part Sources?
TC SERIES
20UF 450V- TC75
40UF-450V- TC78
PVC SERIES
.001UF-600V- PVC621
.002UF-600V- PVC622
.022UF-600V- PVC6122
.047UF-600V- PVC6147
.1UF-600V- PVC601
						20UF 450V- TC75
40UF-450V- TC78
PVC SERIES
.001UF-600V- PVC621
.002UF-600V- PVC622
.1UF-600V- PVC601
