ok guys hope someone can help
I have a '65 Fender twin reverb reissue on my bench
it is making a very loud buzz sound when turned on
I tested the power tubes -ok
I tested the preamp tubes 1 bad (replaced)
plugged the tubes back in same sound
did a quick check for burned resistors (appear ok)
I pulled the PI tube same sound
I pulled the power tubes same sound
I checked the OT for continuity primary to secondary ok  primary to primary ok
my question :
is there a known failure on these amps that would make a loud hum buzz sound ???
like I described
thanks
Dan...........
						Fender twin reverb reissue help please
Re: Fender twin reverb reissue help please
check the primary filter caps if u have a cap tester or if one has come loose or a lead broken--they can go bad-  do u have a scope--you should see major ripple in the B+, or check the B+ (6l6 plate supply) with your meter in AC volt mode-you'll see several volts or more  AC on top of the DCV if the caps are bad-
ok no scope or cap meter
but I will check with volt meter
thanks
Dan
thanks
Dan
If the amp makes noise with no power tubes installed, then the OT is coupling ripple to the secondary. This happened in an amp I built, where an internal wire of the OT shorted to the body of the OT.
It it's not a short in the OT (and some shorts may actually have significant resistance and not show up on a meter--had a bad reverb tranny that would only short with HT applied), then it's got to be a filter issue. I'd say replace EVERTHING in the PS--caps and resistors.
Or, if you have any kind of spare OT lying around, tack it in and see what you get.
Rich Gordon
OK,
butwhatif thank you, thank you, thank you,
learn something new every day
I set my volt meter to AC and checked my plates and found 80+ volts
checked the center tap of the OT and the same 80+ volts were there
checked the PS board and couldn't reach it so I flipped the amp over and the hum went away WTF !!!
then it came back
so I took my positive lead checked checked the first cap pf B+1 and sure enough it sparked!!
the lead coming out of the cap was broken right at the cap
tried to solder it back but it would not hold
I subbed another cap I had and the amp works
now I have to find a 200uf @ 300 volts cap
rfgordon
thanks for your input,
I did suspect a blow OT but then ruled it out by checking with an ohm meter from side to side
again thanks everyone
Dan.........
then it came back
rfgordon
Dan.........
