Help with troubelshooting...
tubedogsmith
Post by tubedogsmith »
Can someone check something for me. On the Overdrive volume pot/ratio pot, with the control turned all the way up what ohmage reading do you get between the wiper and the grounded lug?
Bob-I
Re: Help with troubelshooting...
Post by Bob-I »
tubedogsmith wrote:Can someone check something for me. On the Overdrive volume pot/ratio pot, with the control turned all the way up what ohmage reading do you get between the wiper and the grounded lug?
First off, you'll have to disconnect to get an accurate reading. In the circuit you may be reading other components.
All the way up you should read max from wiper to ground. I.E. if it's a 100K pot you should read 100K. I always measure pins 1 to 3 before installing to choose the closest value.
Oh, and we read resistance, not ohmage. :wink:
ayan
Post by ayan »
Bob-I wrote: Oh, and we read resistance, not ohmage. :wink:
FWIW, ohmage is a prefectly valid word for referring to eletric resistance measured in ohms...
Gil
heisthl
Post by heisthl »
In the FET world we call it Drain Bamage :lol:
www.RedPlateAmps.com
tubedogsmith
If someone has an amp open on the bench could you take a measurement in circuit and let me know, thanks.
Pete
Post by Pete »
One amp of mine I just checked measures 270.5K.
tubedogsmith wrote:If someone has an amp open on the bench could you take a measurement in circuit and let me know, thanks.
tubedogsmith
Pete, thanks, do you have a 250k pot in there?
Pete
Post by Pete »
Nope, that's a 1Meg. (HRM) Measures about 986K when not in the circuit (no wires attached). As stated by others earlier, you can not get a measurment of just the pot with wires attached.
tubedogsmith wrote: do you have a 250k pot in there?
tubedogsmith
Ok, thanks.
tubedogsmith
When I got the problem sorted out I got a reading of 89K on the 100K pot. The problem ended up being a bad contact on the relay board. Thanks for the comments.
