What is the reason for the first cap filters values being 100uf while the rest are 47? Need a little refresher with ps theory.
Thanks,
Rut
Question about power supply filter
Re: Question about power supply filter
Actually the filters are usually made up of 2 caps in series so the value is 1/2.rutledj wrote:What is the reason for the first cap filters values being 100uf while the rest are 47? Need a little refresher with ps theory.
Thanks,
Rut
The first stage removes most of the AC ripple. The second stage removes some more but more importantly it decouples the node from the previous node, so modulation of the rail at the first stage won't affect the second.
