Faceplate/Panel Lettering...What do you use?
FunkyE9th
Post by FunkyE9th »
So I'm thinking of using dry transfers and then putting a clear coat over. Any other alternatives for DIY?
I also saw this... http://www.pulsarprofx.com/decalpro/index.html . Anyone tried it?
Thanks,
-FunkyE9th
kec
Re: Faceplate/Panel Lettering...What do you use?
Post by kec »
That's what I did here...
[img:1024:768]http://img.photobucket.com/albums/v521/ ... eckjr5.jpg[/img]
You could do the laser thingy or the metal stamp then fill with laquer stick.
Ken
Real guitars are for old people! - Cartman
FunkyE9th
Post by FunkyE9th »
Thanks Kec! Nice work. I never thought of using wood for a face plate. I may to try that too. :)
davent
Post by davent »
FunkyE9th wrote:So I'm thinking of using dry transfers and then putting a clear coat over. Any other alternatives for DIY?
Thanks,
-FunkyE9th
That seems a like a product worth looking into. Another option would be making waterslide decals, used them on the surface of projects or under thin Lexan.
Click images to enlarge.
[IMG:150:113]http://img210.imageshack.us/img210/1084/oc44inbu6.th.jpg[/img] Surface and clearcoating.
[IMG:150:113]http://img137.imageshack.us/img137/9817/faceplatecj1.th.jpg[/img] Under the Lexan.
Take care
dave
Yes you can make water slides then use either acrylic lacquer or nitro lacquer.
6-9 coats, let cure, wetsand, polish.
FunkyE9th
Post by FunkyE9th »
Thanks all. Looks like water slides is a another good option.
gearhead
Post by gearhead »
What size is the lettering you are using? I'm going down that path now.
Another option is to just go with the single lettter, ala the original wrecks. I imagine you'd want to make that a bit bigger than if spelled out. Had thought of using metal stamps, but heating each up with a propane torch (in a pair of tongs) and burning it in.
Bob-I
Post by Bob-I »
I create a jpg of the panel to size, and have Kinkos print and laminate it. Stick it on the front using double stick tape.
Tubetwang
Post by Tubetwang »
one of those made to measure wood burner (for logos or what) not is being sold for around +/- 60$ at wood hobby stores...
I just do like Kenny did but... :roll:
I like to keep it simple stupid... :oops:
FunkyE9th
Post by FunkyE9th »
gearhead wrote:What size is the lettering you are using? I'm going down that path now.
I haven't decided yet on size, but I did buy dry transfers to see if I like it. The letters are a little over 1/8". I don't like having to manually line up the letters one at a time. So I think those water slides will probably work better.
