 In my 3 channel build I decided to use a brass bar as a ground bus. I mounted it just below the controls and grounded everything signal related to that bar. The cathodes, the controls etc are all grounded there.
After days of troubleshooting the noise in the reverb, I decided to try another grounding scheme. I connected all the cathodes together and to a single ground point at the end of the bar.
Oh My God.... what a difference. The amp is more open and bright, the buzzing is reduced maybe 80% and the gain is increased maybe 30%.
Now I've got a new issue, audible oscillation in the OD ckt. I swapped to shielded for the drive lead from the pot to board, but it's still there. I suspect later in the ckt and I suspect that shielded leads will handle the problem.
