Criticality of filter cap values
All,
It looks like one of the filter caps in my D'Lite is unreliable. I have a pair of 100u/350V caps in series up front, and four 22u/500V caps for each of the following sections.
The 22u/500V caps aren't readily available from Mouser. Is it worth it trying to find that exact value elsewhere, or are 20u/500V caps sufficient?
Thanks!
Thanks!
-g
						Re: Criticality of filter cap values
It does matter if your the kind who can:
1... Hear a sparrow fart from 100 yards away.
2... Hear the difference between tolexed and untolexed cab.
3... Swear that the $300 wood knobs you've installed do make the amp sound smoother.
I can't hear any diff between 20uF or 22uF but you might.
Wait, am I detecting a note...nay, a symphony of sarcasm?tonelab2 wrote:It does matter if your the kind who can:
-g
perhaps.
Individualism more likely.
I would sub the 20uF and see if you can hear a difference. As you know what the amp sounded like before the change you'll be the first to know if it does have an effect on sound or feel. I personally haven't noticed to any great degree going from 16uF to 22uF in old Fender amps but your ears might be more sensitive to such change.
Since most of these caps are 20% tolerence, a 20 could be 16 to 24. Don't worry about it, unless you really CAN hear a sparrow fart
??????????? Huh ! I thought everybody could !
Johnhenry
 Johnhenry
I've seen Dumbles with 20uf there.   I have also seen them with series 47uf.   I have also seen a rare one with series 33uf!!   So there you go.....   You may prefer 20uf.    Which also may actually measure higher than the cap you are replacing.
Thanks all!  I didn't figure 10% would matter given the typical manufacturing tolerances, but then I'd never have expected 10pF here and there to make much of a difference either...and I learned differently.
									-g
Good point. My "300uf" cap substitutes are marked 290uf (-10 +50).Bob-I wrote:Since most of these caps are 20% tolerence, a 20 could be 16 to 24. Don't worry about it, unless you really CAN hear a sparrow fart
				Fischerman
African or European?unless you really CAN hear a sparrow fart
EEEIIIIEEIIIIII.............Fischerman wrote:African or European?unless you really CAN hear a sparrow fart
LOL!!!   I fart in your general direction!
you should hear more of a Fenderish Harmonic content from the African Sparrow and more of the Marshallish Harmonic content from the European Sparrow !
Johnhenry
 Johnhenry
I just put a flat-u-lator in the loop of my Asswerks...........
Okay, I put refried beans out on our bird feeder yesterday, and voila!  Within 30 minutes you could clearly hear wind breaking from sparrow and starling alike.  Admittedly, I had to be within about 50 yards before it was clearly audible.
I'd post a clip, but I really don't want to soil a good SM-57.
-g
