Does anyone find these instructions for replacing tubes from Eurotubes troublesome? I sure do.
First of all the instructions do not provide any step about being certain the unit is turned off AND unplugged!
I'm sure all of you have had amps that do not have bleeder resistors to discharge the filter caps and sometimes leave hundreds of volts sitting on the screen & plate pins of the power tubes!
In addition to that, I think suggesting that a non-tech try to re-tension the pins of any tube socket is just plain reckless, esp if they're trying to re-tension the pins on ceramic tube sockets which are prone to chip and break if too much pressure is placed on them.
Spraying the tube pins with contact cleaner is a good suggestion, however they really should have made a point of barring using WD40 or any harsh chemical like that if for no other reason the odor it emits
 .  Folks tend to get too liberal with WD40 on everything.
 .  Folks tend to get too liberal with WD40 on everything.Anyway, I just read this instruction sheet & was immediately 'shocked' at it (;- ).
What ya think?
Glen
