Repurpose 5 vac rectifier filament winding?
nuke
Post by nuke »
Thinking out a next build, going through the stuff in the back corner of my garage that's been there way too long waiting for that spark of inspiration.
I can't see any reason not to re-purpose the rectifier filament winding of an existing transformer? I want to power some solid state circuits for switching relays LED and pedal, perhaps reverb too. Seems like plenty of current and with a voltage multiplier should handle everything I have in mind.
Unless there's something I don't know about. My understanding is that the rectifier filament winding just has plenty of insulation and isolation from the rest of the transformer since it connects to the high-voltage supply in circuit.
Re: Repurpose 5 vac rectifier filament winding?
It’s been done successfully many times. Tying the 5V heater winding to the high voltage winding is done to reduce the rectifier Vh-k.
trobbins
Post by trobbins »
Also many cheap ebay style dc-dc converters around to achieve whatever dc voltage you want, including step ups like MT3608 and XL6009 based modules, and even for B+ rails with perhaps 20W level grunt from a Baxandall style (Royer-like) small module.
The step-ups can provide a regulated output level from what is an unregulated dc input, and can avoid using large filter capacitance on the rectified filament output or the need for a doubler or tripler with their diode losses or need to use schottky's. They can also be useful for dc powering preamp heaters.
Post by Stevem »
Maybe more important to your build depending on the gain level your looking for would be to rectify that 5 volts which would give you a nice 6.1 vdc to run the first preamp tubes filament from for a real low noise floor.
Or you could rectify that 6.3 vac, drop that dc down some and then power that first tubes filament.
nuke
Post by nuke »
I had a look at some hybrid integrated DC/DC converters with +15/-15v outputs at Digikey, but most needed fairly tight input voltage.
I'm just looking for a nominal 30v (+15v and -15v) to operate some solid-state switching and perhaps a reverb, buffered loop IO, maybe. Don't need much current or anything special.
trobbins
Post by trobbins »
Perhaps use a MT3608 to generate a regulated +12V or 15V, and then use a 12V to +/-15V converter.
