It's not going to be a lot, to be fair. I plan to keep the magic numbers intact for now. So, the preamp is what it is. I will definitely use your idea of an On/Off/On switch for the PAB in the middle position. There won't be any added parts or changes to the core preamp wiring or arrangement, so there's no reason not to try it.martin manning wrote: ↑Sat Apr 26, 2025 4:15 pm Sure. It'll be interesting to see what you come up with.
My main focus will be on making the amp safer and quieter, so I'll concentrate on the power supply while keeping the preamp as it is. It's incredible how many ideas I've borrowed from your schematic; I went from the "beta forever" stage to "pretty much there" in just one day.
However, I do have a few questions. I'm curious about the reason for removing the R/C network on the send in your schematic?
I was talking with a friend who works on amps, and he suggested adding a 470k resistor in parallel to each of the mains rectifier diodes. I've seen people using 10nF capacitors there, but I can't recall ever seeing the resistors. Apparently, this helps with even voltage distribution across the rectifier and provides some noise suppression. I would love to hear your opinion on this. Wouldn't a bridge rectifier achieve a similar effect? I’m not saying I'm considering adding it; I just haven't seen it in any schematics before, so it's hardly essential. I have seen series resistors, but those are typically used from the transformer secondaries to the tube rectifier, not in solid-state rectifiers. I'm simply asking to learn something new, I guess.
Would you say adding a resistor in series with a treble cap on the master volume could help the amp sound less harsh at low volumes? I did that modification to a JVM I had some time ago, and it made the master control sound more natural across the entire spectrum.
I've also noticed that you changed the OD trimmer network values in your schematic. Could you provide some theory behind that, or point me to a thread where it's discussed? A friend of mine with a #183 clone relocated his trimmer to the back panel and adjusts the value depending on the volume he is playing at. Do you think that’s a good idea?
