ampeg b-12-nf speaker wiring
Can someone explain what is going on with the grounding/feedback loop on this thing?  Someone had already messed with it before me, so i'm not entirely sure how it was originally wired. Is the EXT speaker meant to be left floating when the 4 pin xlr is disconnected, OT is grounded when connected? The EXT jack is isolated from chassis ground. Different NFB settings for different speaker impedances makes sense, I just haven't seen it done this way and want a sanity check.
Re: ampeg b-12-nf speaker wiring
It's a safety thing. The phase inverter has no DC ground unless the speaker is plugged in.
Thanks Martin, that makes way more sense.  I was misreading stuff around the PI and the way the last guy wired things added to my confusion...
To prevent operation of the output stage without a load on the amp it would have been far cheaper to do the Fender thing and just use a shorting jack.
definitely a weird setup. I guess they really want you to use the internal speaker.  I also consider using pin 1 on an xlr for anything but ground offensive.
