seveneves wrote: ↑Thu Jan 09, 2025 6:54 pm
seveneves wrote: ↑Thu Jan 09, 2025 5:35 pm
The normal channel is known for being somewhat whimpy. Had a chance to play an original one recently that was just serviced and I would agree with that sentiment.
Sorry I missed that!  The text is tiny, and the schematic is gigantic on my screen.
seveneves wrote: ↑Fri Jan 10, 2025 4:46 am
I presume I can't use a DPDT to switch in/out the TB circuit for the stock normal channel?
You probably could.  I'm just skeptical that it would be useful, and it raises issues about how to route the wiring without creating oscillation, etc.
When I first started in amp-building, I wanted "all the features" and "everything switchable" for "maximum flexibility."  As time has gone on, I'd look to pedals and loop-switchers for "flexibility" and I mostly just want a couple of great sounds from an amp.  These days, I generally changes amps to change sounds (and typically vintage amps instead of my own builds).
I would recommend getting the AC10 built first & working.  If you want to put a switch on afterward to jumper-past the Top Boost circuit, you can.  If you went whole-hog and built the Top Boost like the add-on units (that mounted on the panel covering the chassis), I suspect the switch to bypass it would be quite easy.
