1. Replace the .001 cap across the 820k resistor after the treble pot with a jumper
2. If this amp is for bass use, remove the 100pF bright cap on the volume pot
3. Change the 47k plate resistor to 100k
4. Replace the 22k resistor between the PI input and ground with 100k or higher, or just remove it altogether.
5. Replace the 1k / 1W resistor in the power supply rail with a choke (this would involve drilling a few holes in the chassis. Don't know if you want to go that far or not)
I have attached the schematic and am wondering if I have the correct componentswondering if I have the correct components and procedure. So for:
1. So I just jump out the cap correct? My electronics is very rusty - wouldn't that negate the resistor?
2. For guitar so N/A
3. Do I have the correct resistor circled in the schematic?
4. Do I have the correct resistor circled in the schematic? In your opinion would you replace it with a 100K resistor or remove it all together?
5. Is installing the choke, in your opinion, worth it?
This will be my first amp modification adventure. Really this is just for fun. Any help would be greatly appreciated!
Thanks,
Paul
