As the title states. Worth pursuing or a fools errand?
I'm thinking of a last build with a AB763 preamp into a bass spec 100 watt power amp section. Has anyone built it? What were the results? Worth trying?
I'm thinking of a low filter spec like the early plexi types to keep it spongy like a twin reverb...
						AB763 preamp with Marshall bass spec power amp?
Re: AB763 preamp with Marshall bass spec power amp?
Welcome back, fusionbear! I only know it's you because of your parallel post on TGP...
I've been hunkering to build a high power clean amp for myself just because. I don't need it, but I find it therapeutic to build...
I love the feel of old twins, but wanted to build something a little different just because I'm weird that way.....lol...
No problem to build really. Personally, I like it better with a vox top boost preamp66Fuzz wrote: ↑Sat Aug 17, 2024 4:21 pm As the title states. Worth pursuing or a fools errand?
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
So I assembled it and am happy with the results...
https://youtu.be/FMvq31hmbhU?si=8Z8jCHMApKHB6Wo2
https://youtu.be/0riuT8hAc6A?si=DtLLxunN0uldhM1l
You did not post enough detail, but if your building this for Bass usage as your title alludes to then consider this.
EL34s have more gain then a 6L6GC does.
So they need less PI section drive signal.
If you want clean head room for Bass then using a 50 or 100 watt Marshall output section may not be the way to go especially if your power transformer current output level is closer to Fender twin / Showman size.
care to elaborate on this?
4x12" w/H75s
4x12" w/H75s
