OCD Fulltone
OCD Fulltone
Hi , I'm searcing the schematic of OCD OVERDRIVE Fulltone , anyone can help me?
Re: OCD Fulltone
The OCD is reportedly based on the Voo Doo Labs OD but uses FET's for the clipping.
http://www.freeinfosociety.com/electron ... hp?id=1208
http://www.freeinfosociety.com/electron ... .php?cat=1
Re: OCD Fulltone
Thanks for the informations , I'll seek in web again .
Sergio
						Sergio
Re: OCD Fulltone
When I googled for it, it seems you are not alone in looking for a schematic.
All my searches were guys asking, "Do you have the schematic for the OCD?"
Re: OCD Fulltone
Deric®
						Re: OCD Fulltone
I have an OCD, and it is fairly well gooped. I can say for sure there are some TO-92 transistors and one DIP-8 underneath.
--mark
						--mark
Re: OCD Fulltone
OK Mhuss , but there are thousand OT-92 and operational amp.
You can tell me the exact initials?
Re: OCD Fulltone
The newer versions of the OCD are not gooped.  There are 3 TO-92 type parts.  2 of them are 2N7000 used as diode clippers and one is for his silent switching/LED.
The op-amp is a TL082.
I believe there are now 4 different versions of the OCD. There are gut shots and clear directions on how to change between v1, v2 and v3 on Fulltone's web-site.
http://www.fulltone.com/PDfFiles/OCD%20 ... _small.pdf
Deric®
						Re: OCD Fulltone
Thanks Deric but I'm not able to enter the link
I don't know
						I don't know
Re: OCD Fulltone
the link is a .pdf file, so you must have Acrobat installed. It opened fine for me.
						Re: OCD Fulltone
I don't know , I've Acrobat Reader , but when clik on link , the screen  become white...boh ...
Re: OCD Fulltone
if anyone does figure out a schematic, draw it out or something. people would kill to have it.
									-skyy amps
						Re: OCD Fulltone
Check freestompboxes.org.
Gut shots and hand drawn schematic with an error, but AFAIK quite easy to correct.
I haven'seen it in detail BTW.
Finally a small hijack on the post. Pls. check my website www.paolomazza.com ( online since at least yesterday!!!!!!) and let me know what you think on the guestbook.
Ciao from Italy.
Paolo
						Paolo
				Bernardduur
Re: OCD Fulltone
Check Freestompboxes.org
The OCD is "just" a VoodooLabs Overdrive, slightly modded. Mods are a tubescreamer like gain control, some value changes and a versatile tone section. Clipping is done with MOSFET's protection diodes to Vref (4.5V).
There are now 4 versions; the last one (v1.4) has an additional germanium diode next to the MOSFET protection diode on one side to make the clipping assymmetrical
Great pedal!
Great pedal!
