That was me and yes, it does make a difference...Fictitiousfreedom wrote: ↑Thu May 09, 2024 12:41 am One more question Martin, someone above mentioned the 3rd gens had the foil opposite of convention, is this true and what is your belief on this? Sorry if it comes up a lot, i have found conflicting info on this specific detail. I always go with what Aikens site says on the matter but after reading how drastic the perceived change is in tone i figure its worth digging. By digging i mean bug someone with far more experience than i. Thanks!
3rd Gen ODS by FictitiousFuzz
- ijedouglas
Re: 3rd Gen ODS by FictitiousFuzz
Ian
That sounds fine, but do you have a link to the datasheet you posted? It seems to show much higher wattage ratings than the one I linked.
[edit: found it, CMF series. Those should be fine. Even though 0.5W is enough for plate loads, I'd go with the CMF65 just for the physical size. Under $0.80 each for 100 ppm in quantity 10.]
I’d go with the outside foil lead to the lower impedance to ground, but I’ll have another look at the 2nd gen layout.Fictitiousfreedom wrote: ↑Thu May 09, 2024 12:41 am One more question Martin, someone above mentioned the 3rd gens had the foil opposite of convention, is this true and what is your belief on this?
				Fictitiousfreedom
Yes, i too am extremely grateful for all of these generous folks. The world is so full of greed and disappointment It’s very nice to know that humanity is still sharing and kind, at least when it comes tube amps lolRaoul Duke wrote: ↑Thu May 09, 2024 1:08 am Thank you and I’m glad my questions were helpful - it took me a long time to work up the courage to start asking, lol.
This community of experts is so very generous and helpful to the new guys like us! I’ve learned so much on this site from these great folks and truly appreciate all the knowledge and patience they’ve extended.
Now on to your next one, lol…
Yup, after how good my 3rd gen sounds i have no choice but to do a high plate skyliner. If nothing else it will keep me from experimenting on this one. I really want to do a version of the SSS or even the Manzamp but the daunting amount of work required to pull those off scares me. I look forward to your future builds man!
Camden
Woodworking, music, tubeamps, art and animation, and DIY electronics
Www.fictitiousfuzz.com
Www.fictitiousfuzz.com/tubeamps
				Fictitiousfreedom
Thank you for your time Martin, i have No problem flipping them And listening to the results. It’s just a bit strange that HAD seemingly did it opposite of convention on purpose.martin manning wrote: ↑Thu May 09, 2024 1:22 am
[edit: found it, CMF series. Those should be fine. Even though 0.5W is enough for plate loads, I'd go with the CMF65 just for the physical size. Under $0.80 each for 100 ppm in quantity 10.]I’d go with the outside foil lead to the lower impedance to ground, but I’ll have another look at the 2nd gen layout.Fictitiousfreedom wrote: ↑Thu May 09, 2024 12:41 am One more question Martin, someone above mentioned the 3rd gens had the foil opposite of convention, is this true and what is your belief on this?
[/quote]
Sorry wasn’t trying to say you were wrong or go passed you by asking Martin. I just saw the opportunity to get his opinion and took it. In your build did you try the foils both ways? If so what was the perceived change? Thanks man!
Camden
Is it known that HAD oriented the caps in any certain way? I don’t see any obvious marks indicating that they were tested, and factory labels, if they have outer foil markings, may in fact be random. Without solid evidence I’d opt for the possible reduction in noise floor.
				Fictitiousfreedom
I am not sure myself but Ijedouglas at the beginning of my post recommended i flip them and that it makes a difference, and i trust his experience. I am intrigued for sure but id rather not flip them because if i cant hear a difference than ill have to swap them a second time to return it to how it is..martin manning wrote: ↑Thu May 09, 2024 7:45 pm Is it known that HAD oriented the caps in any certain way? I don’t see any obvious marks indicating that they were tested, and factory labels, if they have outer foil markings, may in fact be random. Without solid evidence I’d opt for the possible reduction in noise floor.
Also i hate to waste more time on this but the CMF60s on mousers site have two different data sheets with very conflicting specs, this is the source of my confusion. If you care to look i attached the data sheets.
Thanks again Martin
Also, i could not resist and experimented a little. My build is now a little different, ill update the layout to reflect these changes but the summary is…..
V2A
A2-220k
A1-150K
K2- 3k3
K1- 2k2
Mid cap - 6PS - 302
Iv tried a few things with the Bass pot to make it work more efficiently. I tried the 0.001uF across outer terminals and a few other values but i think i need to change the pots value because it’s still not perfect.
I prefer it this way for sure, but its a fine line and i don’t want to get too far in the weeds, that being said if i can find a way to implement the OD trim Pot i think that would be a great addition. The high plate values smoothed the OD a lot and increased headroom, i also seem to be able to get the same tone as before if i run the OD low and the first volume high. I will do another tone demo once I'm completely set and done tinkering.
									Camden
				Fictitiousfreedom
For anyone seeing this in the future using my video as an example of tone i made a mistake. As exciting as it is to realize something is wrong and see how fixing it sounds is, it is equally painful when you spent a big chunk of your life double checking and making videos only to realize you have to make another follow up lol I guess this is the penalty you receive when you stubbornly do the majority of the work yourself even though kind folks have already shared most of it.
Out of the thousands of resistors i have nicely labeled in bins on my wall there was one reel of 10 that was labeled 18? I had more 180ks but they were MF or 1/2 watt so i guess i glanced at the color bands and just hallucinated the bands for 180k. It was in fact an 18k, in the position at the end of the OD to ground. It mostly seemed to lower the output of that channel and just made it whimper. Which is a nice lesson in how to use high plates on the Od.
In my search for the tone i thought i should have gotten i tried basically everything i could find in the common Dumble circuits. The best tone i got was with low plate clean and high plate OD, which now makes perfect since. It possibly rivaled the sound im getting now with all stock values. I always run the same few DI tracks out of my Red eye after changing anything and record it, the files are a mess but i may include them in my next video.
Once i realized the mistake i went back to all original values again but out of educational curiosity i one by one added the different plate values, NFB on V1B, skyline stack, every single variation i could come up with for the OD trigger, ect…
I ultimately ended up at the original values again, i didn't want to honestly, i wanted to make it a little more unique but i am a mere mortal and I think the Dman maybe had demonic helpers or something so i accept that this amp sounds phenomenal and now I’m working on a Skyliner 90s design to itch that other scratch. Just need a good power xformer and no longer are the 50-60$ Hammonds being sold through mousers ebay
 I shoulda bought so many more!
I know im basically the only one posting here but keep an eye out for my next video demonstrating the correct tone. Also keep an eye out for my layouts, if you all are like me and collect them than you'll like mine. I've spent way too much time on building my assets and they are getting really good looking. They also use mostly all readily available parts including the few simple mods to make them more useful in the modern world. They also double as templates. Anyone out there using Affinity Design 2 can download my layout and extract all of my assets, if you want better more organized version email me at Studio@fictitiousfuzz.com I also have schematic templates and assets that are just as intricate and useful. Thanks!!
Camden
Fictitiousfreedom wrote: ↑Fri Jul 05, 2024 9:06 pm For anyone seeing this in the future using my video as an example of tone i made a mistake. As exciting as it is to realize something is wrong and see how fixing it sounds is, it is equally painful when you spent a big chunk of your life double checking and making videos only to realize you have to make another follow up lol I guess this is the penalty you receive when you stubbornly do the majority of the work yourself even though kind folks have already shared most of it.
I ultimately ended up at the original values again, i didn't want to honestly, i wanted to make it a little more unique but i am a mere mortal and I think the Dman maybe had demonic helpers or something so i accept that this amp sounds phenomenal and now I’m working on a Skyliner 90s design to itch that other scratch. Just need a good power xformer and no longer are the 50-60$ Hammonds being sold through mousers ebayI shoulda bought so many more!
Great job Camden! Love the look and the sounds! This is a work of art.
I wanted to ask which Hammond power and output transformers you used for you build?
Happy 4th
Guy
