Well, there is an option to make that happen. See in he files section here: https://ampgarage.com/forum/viewtopic.p ... 08#p365408 , DIY ODS Eyelet Boards. A foot-switchable FET boost is described in that .pdf.
#002 Steel String Singer - almost there
		Re: #002 Steel String Singer - almost there
				Richard1001
                                            2 others liked this
https://www.reichelt.nl/nl/nl/jfet-s-c8417.html?r=1
Very suitable as audio input amp. Low noise, low bias, high transconductance
In my own amp i used this one:
https://www.reichelt.nl/nl/nl/transisto ... 1.html?r=1
I guess what you were saying is that you have 12VAC available for a relay power supply.martin manning wrote: ↑Wed Mar 13, 2024 4:04 pmNot quite sure what you mean there, but if you have a 12VAC source then you will need a rectifier and filtering to make that usable for a transistor boost. The Dumble JFET or the LND boost could be powered from B+5.
Yes. But there is nothing that holds me back to put an additional regulator and electrolytic to step down from 12 to 9V for a booster. Or is there something I've missed?martin manning wrote: ↑Wed Mar 13, 2024 4:47 pm I guess what you were saying is that you have 12VAC available for a relay power supply.
yet I found some 2N4416A in my stash. I don't know the source, from where I ordered them, but they all test good.Richard1001 wrote: ↑Wed Mar 13, 2024 4:32 pm https://www.reichelt.nl/nl/nl/jfet-s-c8417.html?r=1
I put a socket in and try other ones, too.
Cheers
Gerhadr
No, all good!
Add a source resistor trim pot to your FET board so you can adjust the bias easily for each one.
I buttoned it up for the first time.
Cheers
Gerhard
						Cheers
Gerhard
Here is the final result:
I finished the FET boost with relay switching:
There was a diffrence between Martins drawings and what I have done with Erwins relay board, NO2 and COM2 needed to be switched around. But other than that it worked out fine and it gives a good solo boost or just a little hair to the overall sound. Very nice.
And I spend a set of new knobs, I couldn't find oxblood chickenheads so I go with Davies 1470. I think it fits very good to the over all look of the amp.
Cheers
Gerhard
Cheers
Gerhard
Very nice! Adding the FET boost was worth the trip, eh?
It's a nice feature, and prevents me from leaving an unused jack in the amp.martin manning wrote: ↑Thu Mar 21, 2024 5:37 pm Very nice! Adding the FET boost was worth the trip, eh?
G.
