Above is a short clip of the amp that was originally owned by Dennis Herring, and now owned by Jason Isbell. I was really taken with the tone, as demoed, of this amp and felt it was as close as one might get to what I perceived as the "Dumble tone". Lovely clean tones and singing, slightly nasal, overdrive tones. Agreed?!!!
So I thought I would start a thread and see what people thought might be going on under the hood.
Dating this amp is tricky. It looks like Dumble used a redundant chassis to put this together. In another video, Herring mentions that he got the amp at a time that he was using a couple of Fender combos and a Rivera modified Boss Chorus.......1977 onwards? Beyond that, these are the few things I have picked up on....
Firstly, the amp has a master volume. How is this implemented? Like a 4th gen amp or HRM?
Second, it has a presence control on the rear of the chassis that can be switched out via the "mid (accent)" switch on the front panel. ("mid" label instead of accent indicates a very early chassis.
Third, it has a "interrupt ' loop.
Fourth, wooden footswitch. When did he stop using wood?
Fifth, in the reverb ad that Jason presumably bought the amp from, it states that it had 3 x 12ax7A preamp valves. Really? The left hand valve should be a 12AT7. However, though blurry, it does look like it might be a 12AX7.
Sixth, the 1 x 12 cab has no oval baffles and has an EVM 12S (series 2) speaker. Old cab with newer speaker? So, my feelings are that it was possibly made in the late 70s with a speaker change in the early 90s. What I would really like is for someone who has heard a 2nd/3rd gen amp to tell me if they think what we are hearing in the video is from that era or a more modern design.
 Tell me what you think!
