I want to build a Blackface Deluxe Reverb (current project) and a Blackface Vibroverb (next project) AB763. I want the amps without the vibrato on the reverb channel and a mid control added on both channels tho, thx to Rob from robrobinette.com that was quite easy!
I also upped the voltage and capacitance rating of the bias board filter electrolytic capacitor to 50uF @ 100V. After my understanding the 50V voltage rating of the original one gets pretty much maxed out and the 25uF extra filter capacitance are a good idea to combat hum from the bias circuit.
On the Deluxe Reverb the rating of the first two "Dog House" filter electrolytic capacitors was also upped to 20uF so the the loose low end of the Deluxe Reverb gets firmed up a little.
I got a couple questions I cannot answer myself tho, since my knowledge is limited enough so the answers are not obvious to me...
1. I modified the regular main board layout a little bit, spread everything apart more to accommodate for the extra space and added the 68K grid stop resistors to the main board as well (like it was done in Tweed style amps). Does all of that look ok?
2. Do I need the two 100R heater resistors on a 2x6L6 or 4x6L6 amp? Basically all "new" layouts for the Deluxe Reverb show them, but the 2x6L6 amps with a GZ34 tube rectifier (Super Reverb & Vibroverb) and the 4x6L6 amps with a solid state rectifier (Twin Reverb) do not show them.
3. Can a 500V voltage rating capacitor be used for the A/C shunt capacitor, instead of the original 200V voltage rating capacitor, without it causing any issues in the circuit? SoZo only makes 500V "Blue Molded" capacitors and I would like to use a SoZo "Blue Molded" there because the original ones used a "Blue Molded" capacitor in that spot as well.
4. Is it ok to experiment with the NFB tail resistor value on a Blackface Vibroverb style amp? I think with a Weber Copper Cap solid state rectifier, adjusted bias and a 100R NFB tail resistor the Vibroverb will have a little more clean headroom compared to a stock one with a 47R NFB tail resistor and a GZ34 tube rectifier, which I would like. I'm not completely sure if it's fine to change that value in that particular amp tho so I'd rather ask around before I do something stupid!
My last questions needs a little more info added...
I know this debate is all over the internet but I do think that carbon composition resistor add some "mojo" to the amps they are used in. IMO it has more to do with the second harmonic distortion that carbon composition resistor add, rather than the almost mystical sound qualities some people believe they have...
 Carbon composition resistors only make sense in a couple strategic spots tho, spots that have high voltage across the resistor and spots that have large signal swings across the resistor. Only under those conditions will they give the amp enough second harmonic distortion to benefit from. Everywhere else they only add noise because those resistors do not have enough high voltage and large signal swings across them for them to produce an appropriate amount of second harmonic distortion that is worth the extra hiss. If introduced in the early stages of the amp the hiss will also be amplified by the later stages, which will add up, so metal film resistors are definitely a much better choice in that case.
That means the PI plate load resistors (100K & 82K) in the last gain stage before the global feedback loop, or the phase inverter if the amp has no global feedback loop, are the perfect choice.
They are also a good choice for the grid stoppers (1.5K and 1.5K) across the power tube sockets. A low inductance resistor, carbon composition resistors have very low inductance, is perfect for that purpose. They tend to fail short and not burst up into flames and fail open, like metal film resistors could, as well, which is a good idea in that spot too.
I heard they are also good as power tube grid leak resistors (220K & 220K) in the output stage as well. I haven't found much information about that sadly tho, which leads me to my last question...
5. Do the power tube grid leak resistors (220K & 220K) in the output stage have enough high voltage and large signal swings across them for carbon composition resistors to make sense in that spot?
6. Are there any other good spots to add carbon composition resistors? Maybe the phase inverter grid leak resistors?
My layouts also show an extra bias filter electrolytic capacitor and a reverb noise filter capacitor to reduce hum and noise. I'm not sure if I will install them but I think I will try the amps without them first and after they are finished clip them in with alligator clips to see if I like the change or not.
