would be the plan.
Any other suggestions/comments/criticisms...
Can you clarify what’s confusing?ChopSauce wrote: ↑Sun Jan 09, 2022 9:22 am … to add to the confusion, Merlin Blencowe suggests (Fig. 14.6: Practial high-gain preamp circuit; p.258 of his "preamp book") that (almost) this tone control be placed in a similar configuration as suggested by Rob Robinette and advocates that the filter should not be loaded (by the following stage?) - as far as I understand things - which sound as the exact opposite of what the simulator suggests.
American slang for have you 'thrown it into the scrap/junk pile'?
Ok, so you have already changed it then.
When driven by a follower, the high end is preserved and response should be quite flat when the control is all the way up.
Yes, Tweed amps are quite flat in the EQ and the Framus will scoop out that midrange, morphing it into something different.
