Wow, I get keeping the signal return above ground, to be above noise and digital hash, but 10k seems a little high no.Stopping-by432 wrote: ↑Thu Jan 06, 2022 2:50 pmI am not sure as UA does not disclose that info. It only shows that the ground input goes to ground across a 10k resister and the tip goes to reactive load.
Tubes buzzing with UA Ox
Re: Tubes buzzing with UA Ox
				Stopping-by432
                                            3 others liked this
I am not sure exactly, I just relayed what I was told by UA.
I was able to find out what was causing the oscillation and I fixed it this evening One of the switches was bad and it caused a grounding issue.  I replaced the switch and the oscillation was gone!   Thank you to everyone that assisted with the troubleshooting.  I learned a lot during this process.   Now I get to enjoy the amp for a while until I get the itch to build the next amp.
   One of the switches was bad and it caused a grounding issue.  I replaced the switch and the oscillation was gone!   Thank you to everyone that assisted with the troubleshooting.  I learned a lot during this process.   Now I get to enjoy the amp for a while until I get the itch to build the next amp.Re: Tubes buzzing with UA Ox
....one of the switches controlling one of the Robinette mods? When you seek help here remember the door swings both ways. If you made a mistake wiring something up or you ran into a modification that caused a problem it's best to leave your ego at the door and tell the ppl that tried to help you what caused the problem.
				Stopping-by432
It was the raw switch mod that I tweaked by using a DPDT switch.  The ground of the presence pot was lifted when it was supposed to stay ground at all times.  I should have just grounded the presence pot directly but I tried to accomplish the same with the switch and keeping it connected to ground with the middle control so the circuit remained in tact when off.  I ultimately did this when I replaced the switch.  My apologizes for not explaining this earlier.
Thanks for this update!
				Stopping-by432
Sorry I posted to an old message by mistake.
