talbany wrote: ↑Fri Sep 03, 2021 11:20 am
Dumble experimented around with different layouts and tube placements. He also tried to lower noise floor from the power supply by placing the filter caps closer to the source (plate resistors) but you have to wonder why he didn't continue with the practice?. Perhaps he didn't see the added benefits and or costs (money or time) to convert his manufacturing process and design specs.
money is out of the equation, because from one amp he can live for 5-10 years
IMO it was experiment to develope more his approach and see the result
IMO even if you change the layout to a so called better more improved method to try and compensate for a particular anomaly or side affect. The question would then be? did the modification change (in your opinion) improve the overall sound and performance of the amp (emphasis on sound)
i always hope for YES until i change opinion after i see that is a miss
for me the best sound is always when you put first tube directly below the input socket (now we can discuss why but is trivial
) , this increase the quality of highs to better , more open and organic, heavy, not thin .. if you compare this approach to marshall amp, then marshall is too dull (from tube socket to the pots every wire is 20cm+ and coming back ) .. what does it means? from my experience - shorter paths = more highs, longer paths=less highs. dumble arrived to the same point and probably left all tubes on the back side of the chassis, because OD was maybe way to shrill with some pedals.
i tested idea in my builds/ not following dumble layout/ first tube below input socket, OD tube far away (adding capacitance) and i get some results!
here it is important that feeling of "highs" is generated in the output transformer in conjunction with output tubes and the speaker, with main factor output transformer . if the transformer is not so appropriate, highs are more pronuanced and "unpleasant", the best trafo is filtering them out before the speaker and amp no need / or need only basic tuning. so story about too much heighs in the amp is also a story about the OPT used.
so i want to say that if you follow exact dumbles ideas, you need to follow also his layout and this is difficult because you dont know what the guy thought in that moment..A lot of clips of "Dumble" ODS on the net are fuzzy sounding like "broken" or somebody making holes with screwdriver in the speaker
lead dress? or he pays the tribute that build was custom- dedicated for one guitar only and not good for others? component failure or drift? if you are dumble you will know but for all of us is a mistery....
