Make large rectangle holes in 1.6mm steel chassis?
TUBEDUDE
Re: Make large rectangle holes in 1.6mm steel chassis?
Post by TUBEDUDE »
I haven't had any issues with the Dremel cut off wheels. The thin fragile flat disks yes, but not with the thicker reinforced ones made for metal.
proxy-image (12).jpeg (12.05 KiB) Viewed 3347 times
Post by Bill Moore »
I had to open a chassis for a larger transformer a while back, so I took it to our local machine shop. I drew out the lines to cut, and they milled it out. I drilled the mounting holes after I got the chassis back, and it wasn't much money!
ChopSauce
Post by ChopSauce »
You're lucky if there is some machine shop around you, but I live downtown and there are almost only banks, real estate agencies and hairdressers - but a few shop selling something to eat - around me.
Phil_S wrote: Wed Mar 31, 2021 12:37 amMaybe with 1.6mm material, the jig saw is OK?
I did that. Even with 1.6mm thick steel, I would be carefull at the edges, managing to have the parts as supported and even clamped as possible.
About cutting disks: I have always been amazed watching some people doing precise cuts with that. I know that works!
For some people it does work very well, really, but it's just not for me - yet I sometimes manage to improve my skills doing that, when working on non critical parts.
TUBEDUDE
Post by TUBEDUDE »
This dremel accessory simplifies cuts.
ChopSauce
Post by ChopSauce »
I have the same. I only use it to cut my tack welds needing to be redone - generally parts to be re-positionned for the weld tend to pull them out of place, when the metal turns back to cold.
Stephen1966
Post by Stephen1966 »
+1 for the Dremel (and a step drill at the corners). Just done a 2mm aluminium chassis like that.
Stephen
Stephen
www.primatone.eu
