Niki
I would take both PT center taps to the same ground lug.unknowntome wrote: ↑Sun Mar 07, 2021 10:36 am Hey everyone - just touching base as ive done my best to add the power section to the layout that BobL posted. I've cut and paste the power section from the 5e3 layout on Rob Robinettes site which has been an invaluable resource for me and no doubt loads of others. I was hoping someone could take a glance and let me know if it looks ok? Im really in the beginning stages of getting into DIY tube amps having spent most of my focus on pedals. Cheers!
https://imgur.com/seo1xTe
BobL wrote: ↑Mon Mar 08, 2021 5:04 pmI would take both PT center taps to the same ground lug.unknowntome wrote: ↑Sun Mar 07, 2021 10:36 am Hey everyone - just touching base as ive done my best to add the power section to the layout that BobL posted. I've cut and paste the power section from the 5e3 layout on Rob Robinettes site which has been an invaluable resource for me and no doubt loads of others. I was hoping someone could take a glance and let me know if it looks ok? Im really in the beginning stages of getting into DIY tube amps having spent most of my focus on pedals. Cheers!
Your AC cord will go to one side of the fuse and one side of the switch, then your common and wall voltage taps from your PT will go to the other side of the switch and the fuse.
I built w/o a standby switch, so that was different on mine.
If you can find a PT that is putting out less voltage, you will get closer to the measured voltages - I used 300v taps on mine with a 5Y3, and hit pretty much on the money, voltage wise.
When I was running it into a pair of P12Qs it was pretty dang quiet... Maybe an option? That is my go to move for 'too loud'... That and using pedals to gain stage/turn down. I had to get more efficient speakers for it to hang with the band (Eminence GA SC-64s, which sound great with it).pullshocks wrote: ↑Wed Mar 24, 2021 9:38 pm
The amp is way too loud for my needs, but sounds really good. I've got it hooked up to a Celestion G12H30 (75Hz), as used in many of the demos that can be found on line.
I may look into building an attenuator as designed by John H on the Marshall forum. Or try a lower watt version
Hi Roberto, would you mind elaborating on this comment, particularly about the low order harmonic design? It sounds very interesting, thank you!roberto wrote: ↑Thu Feb 18, 2021 9:10 am Nice design: a 110k 2k2 stage with half the resistor values on the first stage to increase low order harmonics, and a drastic split load on the second that is like having a volume pot at 5 but with way more bandwidth (and a bit more noise from the psu node), with a very low loss between first two stages.
pullshocks wrote: ↑Wed Mar 24, 2021 9:38 pm Based on some discussion on the Hoffman forum, I replaced the 250pF reverb output coupling cap with a larger value--0.005 uF. This gives a lot more verb, and a lot better reverb tone. It was very bright and harsh with the 250pF.
Bob L hasn't posted here for a while but apparently he has confirmed that the xEBxxx tank is the way to go.
The good news for me is the xFBxxx tank does work and sounds good, despite not being the best match.
I finally got around to updating the drawings I posted on page 3. Sorry for any confusion.
