Dumbleator 240v transformer
Hi. Any advise on what EU powered transformer for the Dumbleator? Tried to find on here, but didn't?
Re: Dumbleator 240v transformer
I used a Amplimo 1n242 toroid pt.
At tube town you can get something similar:
https://www.tube-town.net/ttstore/toroi ... l-520.html
What voltage is optimal on the secondaries?
I am still a bit uncertain about the transformer, what about these specs from TubeTown?:
Pri: 0-220-230-240 V (schwarz-gelb-lila-rot / black-yellow-purple-red)
Sec 1: 250 V @ 0,12 A (red / rot)
Sec 2: 6,3 V @ 3 A (green / grün)
freie Enden / long leads ca 200 mm
h= ca.40mm d= ca.80mm
50/60 Hz EN 61558
You get a slightly higher B+ which can be adjusted with the first resistor of the dropping string.
Higher value dropping string resistor = lower voltage on the following filter nodes.
Erwin
Erwin
