BLUF: Improvement, but still gremlins. I am going to be pretty verbose in case anyone else has similar problems in the future and stumble upon this thread.pompeiisneaks wrote: ↑Mon Nov 02, 2020 9:28 pm I ended up with some oscillations in OD due to the leads being to close between the first stage and the second, I ended up swapping the triode sides on V1 so that V1's first input was farther away from the V2 OD tube, This could be similar behavior you weren't getting when it wasn't working as optimally? Try at a minimum carefully putting some kind of grounded shield between V1/V2 and see if that does anything. Just don't touch the anodes or you can create a disaster.
I feel like I might have accidentally turned my OD channel into a Theremin for a while there. I was sweeping the input volume and it totally sounded like an electronic slide whistle. I thought the mothership might come land.
I did a quick shield test like you mentioned and it did help me resolve some issues, but not directly.
I took a small piece of metal the size of a baseball card with an alligator-clipped lead to ground, held it with plastic tongs, and tested holding it in various positions to shield things. At one point I bumped one of the eq leads and the noise changed drastically in pitch. I tapped the wires connected to the bass pot and it was almost musical the way the noise changed pitch. Almost.
I am still very new to understanding signal paths and how amplifiers work, so it took me taking what little I know about pots and following each wire and guessing whether or not signal was going one direction or the other to figure out what might be going on.
I took a bamboo skewer and gently started moving the leads around near the bass pot and I was able to silence the Theremin tones momentarily when I tapped on the wires. I isolated the cause to be the shielded cable ground from pin 3 of the drive pot. I ran the skewer between them and the noise halted. As ChopSauce had warned, adding the shielded wire opened me up to new and exciting errors in amp building.
Tell me if my thinking here makes sense, please:
I think a fine hair of the shielding wire that was too small for my eyes was making contact with pin 1 on the bass pot and pin 3 on the drive pot, so when the OD was activated and signal was going through the drive pot and some of that signal was getting fed back in where the bass would have fed if it were maxed, which is why it only occurred when the PAB and OD were both engaged, creating a feedback loop. As I understand it, the PAB essentially removes the tone pots from the circuit, effectively maxing them out. Is this correct?
