Everything weird happens between 4 and 6AM
- Reeltarded
10h-.68u over 2k7. The neighbors have to be truly impressed. The peak is near 100Hz. I upped the plate to 220k no bypass required.
Tried it on stage 3. Dropped a tad more gain that I bargained for although the action plays out more plainly as a late stage bypass. It's by no means lost in translation as stage 1. It makes a lot of sense. (and a tremendous roar.. rawr..)
I need some screws!
I need some screws!
						Re: Everything weird happens between 4 and 6AM
You're using a choke for that?  I had something smaller in mind like inside the chassis .
  I had something smaller in mind like inside the chassis .- cbass
Do these do stuff?
						- Reeltarded
Yes. Where did those come from? That sure fits better and doesn't freak out if it's oriented poorly. LOL
						- Reeltarded
10H and .68u resonates at 107Hz. Larger cap lower peak.
Good calculators based on the things you know values of.
https://rimstar.org/science_electronics ... ircuit.htm
Organ donor. You can have them if you want. theres about 12 or so
- Reeltarded
I just need one 10h for a cathode that doesn't have to be mounted to the side of a headbox lol
				Ray Barbee
I feel like I missed part of the conversation.  Is there a schematic?
Nope.  Ain't no schematic, buddy.
				Ray Barbee
What are we talking about here?  Adding an inductor across an Rk to try to get a specific frequency boost?
						- dorrisant
I wonder how this worked out for him.
Miles! You have some splainin' to do...
Btw, what's up Ray? Haven't seen you in years.
