Pedal wiring for 50w D
Hi. Is there a wiring for 50w D channel selector pedal. I am using a regular XLR female?
- pompeiisneaks
- Site Admin
Re: Pedal wiring for 50w D
The #124 that I built has a schematic for it on the layout page: https://ampgarage.com/forum/download/fi ... &mode=view and the actual schematic:
https://ampgarage.com/forum/download/file.php?id=4805
basically you should be able to put together the idea there. I think I also read you don't 'need' the 0.1 uF caps on both the switches inside and the footswitch so it's best to just put them on the inside so they're always part of the circuit. I think I still did it on both though
I just built a pedal using the 124 schematic. I didn't use caps on any of the switches and I don't get pops when I activate the switches. I'm not saying that you should do the same. Just letting you know my experience.pompeiisneaks wrote: ↑Sun May 03, 2020 9:48 pm
- norburybrook
I've never put them on any of my ODS buildsdonvan wrote: ↑Mon May 04, 2020 3:04 amI just built a pedal using the 124 schematic. I didn't use caps on any of the switches and I don't get pops when I activate the switches. I'm not saying that you should do the same. Just letting you know my experience.pompeiisneaks wrote: ↑Sun May 03, 2020 9:48 pm
M
