jfs322 wrote: ↑Mon Apr 13, 2020 5:32 pm
pompeiisneaks wrote: ↑Mon Apr 13, 2020 4:19 pm
norburybrook wrote: ↑Mon Apr 13, 2020 12:09 pm
my understanding is the inductor does absolutely nothing to the tone so not having it there is the same as having it there
I could be wrong of course on this.
M
I too remember someone here on the forums saying they did a detailed analysis of the circuit with spice or some other software and could clearly state that there is 0 impact to the inductor in he circuit. I'm no expert myself, so I'm only relaying what's been said here.
I'm not an expert either, but I wonder if the inductor really is doing something (at least in the early models) and the community is just not getting the filters 100% correct? My only reason for thinking this -- and perhaps I'm speculating -- is that the guys at Two-Rock, who have been inside SSS #002 and #004 (as well as some Dumblelands) (and thus have had more inside knowledge of these amps than perhaps anyone) still use an inductor on their SSS builds. And I'm presuming that they are smart guys, so presumably if when inside they saw that it does nothing, they wouldn't have bothered including it? Or maybe I'm give them too much credit, and they simply missed it but we've caught it? Or perhaps they too noticed it, but still include just for the sake of accuracy? In any event, Dumble ditched the inductor by SSS #005; it's been confirmed by Brandon that there wasn't an inductor in #005, so perhaps Dumble discovered his mistake or simply redesigned the filter network of the earlier SSS amps to no longer require an inductor?
Band Pass Filter using R, L and C Components
Band Pass Filter circuit design by using inductor, capacitor and resistor is given as below:
The centre frequency of the band pass filter which is also termed as ‘resonant peak’ can be formulated by using the below equation:
fc = 1/2π√(LC)
Where L = inductance of an inductor whose units are in Henry (H).
C = capacitance of a capacitor whose units are in Farad (F).
We can also design a band pass filter with inductors, but we know that due to high reactance of the capacitors the band pass filter design with RC elements is more advantage than RL circuits.
This is (basically) the same filter network Ampeg used on their SVT and other amps (via rocker switches).Perhaps Dumble had a setting he liked?? Clearly the SSS was inspired by the SVT (AB2).I can also say that jumping this filter out in my #002 clone has little effect on the sound. This would be a question I would want to ask Dumble if given the chance?
BTW.AFAIK The (Hi-Lo) filter array in the hand drawn #002 from Japan is correct! However impractical on some settings . I believe the one Martin posted a while back is better suited for 6 string electrics IMO..
