50w 183?
Oddvar R
50w 183?
Post by Oddvar R »
Hi. Just thinking about making the 183 into a 50w amp. Is there anything else than just omitting two output tubes from the circuit?
10thTx
Re: 50w 183?
Post by 10thTx »
Compare the bias circuit of a known Dumble 50w amp using the tubes you're gonna use (6L6,5881,EL34,KT66, etc...) and contrast that with the 100w 183 bias circuit.
With respect, 10thtx
Oddvar R
Re: 50w 183?
Post by Oddvar R »
Are there any 50w layouts around?
pompeiisneaks
Site Admin
Re: 50w 183?
Post by pompeiisneaks »
They'd literally be the same w/o the extra tubes and a specifically different OT to support the different required plate load, thus 10thTx's point.
Power Amp side everything is equal and you just adjust the OT for the number of tubes, you could even possibly do 150W with 6 tubes but you'd need to beef up the PT likely for more heater current and HT current for the extra tubes :D
4x power tubes just require 2 more sockets, 2 more grid stoppers, 2 more screen droppers, and a bit of jumper wire for the OT primaries to share the load on each side. Then the OT of course. If you're doing 2, just omit the xtras.
norburybrook
Re: 50w 183?
Post by norburybrook »
you're forgetting that to keep the same feel of the amp you would need to half the main filter cap values.
M
Re: 50w 183?
...and adjust the GNFB resistor.
pompeiisneaks
Site Admin
Re: 50w 183?
I stand corrected, those definitely both make sense. Although filtering usually in dumbles is pretty stiff already, I don't think adding more power filtering is 'horrible' in that case no? yes?
The GNFB would definitely change the tone of the amp and needs adjusting, my apologies :D. It's based on the actual OT impedance ratio right? Something I still have yet to figure out fully. I've seen people showing the calculation to adjust for different taps etc, but still have never seen a super great explanation of it.
Oddvar R
Re: 50w 183?
Post by Oddvar R »
martin manning wrote: Tue Oct 01, 2019 5:52 pm ...and adjust the GNFB resistor.
What would be recommended here?
Re: 50w 183?
For half the power into the same speaker load, the voltage is reduced by a factor of 0.707, so I’d start by reducing the FB resistor by that factor. You may want to experiment with that, though.
10thTx
Re: 50w 183?
Post by 10thTx »
I looked thru my D files and found these 3 schematics. Maybe something of use in there helping with bias, NFB, etc.....
