Filtercaps, how to assemble?
Hi.  Just sourcing my Express build, and I am wondering how the filter capacitors are assembled in the chassis,  Is it just put on the floor so to speak? Or is it assembled on some kind of turret board?
						Re: Filtercaps, how to assemble?
they are glued basically. hardly an optimal solution
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
So I'll just make a turret board then.
If you haven't made your board yet I like building the cap board like this and add the other filter caps on the main tone board.
Other wise you can build the cap board all together under/over version.
Hi and thanks.  On the last picture you have three under the board and three on top?
				RockinRocket
Glue is absolutely fine if the chassis is 2" tall with a bottom plate just like Ken did them. Spargue atom caps fit perfectly. Once they are glued and soldered in with solid core wire theres no way they will become a safty hazard IMO.
				wpaulvogel
Me. Fowler,
Do you make your chassis of do you have someone that breaks it for you.
Both of those chassis appear to be WattsTubeAudio which I think Ken Watts is still out of business.
rjguitars.net might have some in stock otherwise, on ebay under 17x8x2 tube amplifier chassis there are sellers that I have used.
In United Kingdom modulus Amplification sells TW style chassis and other types of chassis as well as parts.
