Marcus, my buddy is also building the same amp, so he wanted OD on a foot switch.... so good idea thanks
Tweedle Dee build
				andresound
Re: Tweedle Dee build
Martin, I will try bigger resistor  .
				andresound
Cabinet Tolexing. My pet hate. But I am improving. Will load everything today, just waiting for a face plate
				andresound
Calling her done. Thanks for all the help on the forum. Time to try her in a band situation. Fine tuning and tube rolling to come.
Looking good! Let us know how it does with the band. Did you add any mods to the standard Tweedle Dee circuit? The beer is just for a size reference, I guess ;^)
				andresound
Thanks Martin. Will let you know, and thanks for the help. Most appreciated  . Yes the beer was for size reference
				andresound
Martin, no mods yet. Guitarist used the amp last night and loved it. I briefly played it and thought it needed a bit more headroom. We do rehearse in a VERY “dead” room, so that might have contributed. However, I still need to adjust voltages, (bring the B+ up with a GZ34), and increase cathode resistor. I have noticed that when the cathode resistor is hot, it measures higher, which I assume in theory, would cause the tubes to run at a lower dissipation/wattage? Will revisit that.martin manning wrote: ↑Sun May 19, 2019 2:09 pm Looking good! Let us know how it does with the band. Did you add any mods to the standard Tweedle Dee circuit? The beer is just for a size reference, I guess ;^)
				andresound
Put the GZ34 back in and prefer the sound of the amp “hot”. I am not getting any red plating. I don't mind replacing tubes  . I’m not a professional player, so the tubes should last a while. I know you guys don't like the bias calculator, but anyway.. this is what I got. My only problem is the heater voltage is 6.9v. Should I “pad” this with series resistors?
						- pompeiisneaks
- Site Admin
I don't think slightly higher heater voltages will hurt, it may also shorten the life of the tube a bit, but again, not likely by much, the max heater voltage I remember seeing in some datasheets back when I researched this due to an EL34 being shorted from pin 3 to 2 was like 50V on 12A*7 types and 100V on many power tubes.  This is the maximum before pretty much instant death to the filament of course, but anything over the expected rating will shorten the life I'm sure.
				andresound
It’s on the high side, but 6.9V is still within the +/-10% criteria specified in most data sheets so you are ok.
				andresound
martin manning wrote: ↑Fri May 24, 2019 4:24 pm 6.9V is still within the +/-10% criteria specified in most data sheets so you are ok.
