I'm 95% done wiring up my modified Marshall JCM800, which ended up being a total rebuild. Even redid the preamp heater wires, as apparently Marshall hired a chimpanzee that wasn't able to twist wires around the late 70s/early 80s...
Ground schemes have probably been discussed a ton on here, but I can't seem to wrap my head around it. The ground bus has been moved from the pots and is soldered to two ground lugs attached to the circuit board (just through two holes in the board, the lugs are not grounded to the chassis) to avoid any ground loops. What I have done so far/plan to do:
- 32 uf (for extra tube/gain stage) and 50+50uf preamp filter caps sharing one star ground
- star ground close to input connected directly to input jack, and also directly to the start of the ground bus which will connect to every ground connection in the preamp and bias caps
- 100+100uf and 50+50uf power amp filter caps grounded separately on one star ground each
It's the two first ones I'm not sure about, because in my head you shouldn't connect too many things to one star ground... And also, the actual ground lug for the preamp filters wouldn't be able to fit more than maximum one more wire anyway. Which is obviously fixable, but still.
If you could help me out that would be amazing, as I really want to get this amp up and running tomorrow... To be fair I haven't actually tried it with this ground scheme, and for all I know it works perfectly fine. It's more that I want to make the amp totally bulletproof/failsafe so I can put it back together and not open it up again until the filter caps need changing in 20 years (yes, I installed an external bias pot
Cheers!
