pdf64 wrote: ↑Mon Mar 18, 2019 5:45 pm
Do you really need to have the normal channel in use at the same time as the overdrive channel? Bear in mind they're in opposing polarity.
It's just that the 220k - 470k channel mixer resistors are losing you ~1/3 of the max available signal level from the overdrive channel, ~2/3 from the normal channel.
A switch to select one channel or the other would get around that, perhaps relay operated, or vactrols if you can get them.
The OD tone stack may be more lossy than necessary, due to the 100k slope resistor; consider bringing it down a bit (eg 68k, 56k) and retweaking all the other stack component values as required.
And as there's not much gain after it, a linear taper master vol control may provide a better 'user interface'.
It would be a lot better to put the bias supply feed resistor BEFORE the standby switch, as the power tubes will be having a very rude awakening in it's current arrangement
Now you're getting me ready to pull out that chassis once again...
So you're saying that the mixer resistor from the clean channel is a path to ground for the lead channel...back to where? The plate?
This mixing solution is seen in loads of old two channel amps, I've never regarded those mixers as voltage dividers.
RE the slope resistor, I have learned that a larger value = less load (higher impedance)? I deliberately went up from 39K to 100K with that in mind.
Well, I had thought of a channel switching option. Where I would tap the signal after the clean channels 1st stage, into the two stages of the lead channel, and back into the clean channel 2nd stage. Maybe I should have done that after all...
@pompeiisneaks: Yes I would put 1-3 more tubes in there if I wanted to make the ultimate overdrive amp.
Think I'll have to show a little history of this amp. It's an English amp made in 1969, Partridge transformers, two identical channels and looks about as cool on the inside as it does on the outside.
When I bought it a couple of weeks ago it was basically untoched, down to electrolyctics dated 1968.
The stock circuit was so bright it was unusable. As I thought there were Marshall-like tones hiding in it, I started digging them out.
I don't want to ruin the appearance, and I like to keep as many original components as possible on the tagstrip board.
So I wanted to stay within those confines. But swapping a switch for one of the input jacks would be fine.
Someone had already drilled a hole in the back where I put the master volume.
I thought I could do channel switching with my ABY box.
Here is the original schematic and some pictures.
