You are correct, none of the other two methods I read about even mentioned removing the resistor or wire. I guess they understood people following those steps would be advanced enough to know. Which you could see I was not.martin manning wrote: ↑Wed Mar 06, 2019 10:18 am And why not leave the resistors in place so you have the option? As I said above, they won’t affect the results you’ll get using the OT primary resistance method.I’ll bet you’ve never seen a recommendation to remove the one ohm resistors and leave the cathodes ungrounded either!
But I feel it is a learning process and you guys taught me that something has to be there. You taught and I learned, sounds like a win win to me.
