Would appreciate any input as to whether I have this correct, or not.
Don't take this the wrong way..Stevem wrote: ↑Mon Feb 18, 2019 11:56 am Why is it you want to remove that circut from the amp?
That type of Tremolo circuit really does not sap any drive signal away like the amps that use a opto coupler as part of the Tremolo circuit so just don't turn it up!
Don't take this the wrong way, wiring pictures are great, but you need to learn how to read a schematic my friend!
Thanks, sluckey.
Ok, so the other half of the 12AX7 is the phase inverter ?
I'm going to use the remaining parts to build a pre-amp of sorts.
I appreciate that.pompeiisneaks wrote: ↑Mon Feb 18, 2019 6:41 pm I'm going to chime in as the admin/mod to avoid this getting snarkier.
Cathode ray, I didn't read stevem's response as snarky, instead it was very intelligent and to the point. Since you hadn't really explained the 'why' of the removal, his answer, in a specific situation, is a perfect one.
If you have an existing amp, that has the trem circuit, he knows just turning it down to 0 doesn't change the circuit at all, and lets it keep working as is. Also his comment about the layout vs schematic was very valuable, it was even mentioned here as well. Layout's can be tricky to read/understand but a schematic is generally much easier to read/understand.
I think your snarky response to stevem then led him to respond snarkily as well. Both of you at this point need to give that a rest, as it won't help the conversation.
sluckey and martin have given you some great info after your clarification that you don't have the existing amp and want to restore it minus the trem. In that case, is there a specific need to install a 6G2 circuit in it? You could find any other amp you think would be great to build with two 12A*7 tubes and dual 6V6 output. A Deluxe, a Tweedle Dee Deluxe, etc. there are tons of options left to you if you just have the chassis and transformers etc.
Good luck with the project.
I apologize for my frustration as well.Stevem wrote: ↑Tue Feb 19, 2019 11:36 am My responce to him was also in regards to the fact that many of the Fender amp drawing layouts are known to be wrong, but only very few of the schematics, I guess I should have made note of this in my post, sorry!
Believe me when I say that when I intend to be sarcastic and condescending you'all know it, lol!
