2 x 4 cab....2 or 4 on?
Can I install a switch that would allow me to run either 2 or 4 speakers in my new built 2 x 4 cab with Celestions in it? I want to use two for smaller venues and four for larger ones, or when I want to drive two speakers at a lower output.  Impedence isn't a prob cause I will have 4, 8. 16 on the output.  I was able to get this from a really far out dude.  How's this??
Merrry Christmas....!!!!
Brian
Brian
						Re: 2 x 4 cab....2 or 4 on?
Yes, but it depends on what you want to do with it.  If you'd specify a bit more, that's be great.
						- VacuumVoodoo
Not if you want 2 speaker combination to have same impedance as 4 speaker combination.
If each speaker has impedance "R":
2 speakers can be connected to give 2R or R/2 total impedance
4 speakers can be connected to give 4R or R or R/4 total impedance with reservation connecting 4 speakers in series for 4R impedance is not practiced.
If your amp has, say, 8 and 4 ohm outputs and each speaker is 8 Ohm than it can be done.
Wait till tomorrow for a drawing.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Oh man....sorry for the left out info.  I left a post on the "other" site and didn't follow up here with all the info.  Corrected in the original message........
						- VacuumVoodoo
Are there separate 4,8,16 ohm outputs on the amp or an impedance selector switch?
									Aleksander Niemand
Zagray!-review
Zagray!-review
There is an impedance switch.  I have three heads and they are all wired this way.
BH
						BH
- VacuumVoodoo
Ok, here you go.
A 3 position 2 pole rotary switch allows you to choose between 2 or all 4 speakers. When using 2 speakers you have a choice of running the disconnected 2 speakers undamped, they'll behave like passive radiators, or damped with their voice coils short circuited.
Remember to set impedance selector on your amp accordingly.
You can skip the damping position and use a pole 2 position switch.
Now, please deposit whatever amount of money you deem this is worth to you into my off shore money loundering account.
									Aleksander Niemand
Zagray!-review
Zagray!-review
OOOKKKKKKKKK!!!!!!!!!!   Account number and pass code please!!
Brian
						Brian
...and your original drawing will work fine, if the unused speakers being "undamped" is not a problem.
VV, is there really a large difference in sound damped vs. undamped?
--mark
--mark
- VacuumVoodoo
In a closed back enclosure there's a distinctive improvement in bass response when unused speakers are damped, at least to my ears.mhuss wrote:.
--mark
Use a "make-before-break" switch and it'll be very easy to do on the fly A/B test with my switch arrangement as you won't be interrupting signal to the active speakers when changing between damped/undamped.
Aleksander Niemand
Zagray!-review
Zagray!-review
You don't need double pole switching. Try this:
Edit: missed VoodooMan's damped/undamped. In the below the 16ohms are damped while the 8's are undamped. I've never experimented with damped undamped (or turning off speakers for that matter!) so have no opinion
Well....thanks to all the great answers, I will have to try the dumped/notdumped switch.  I will report back on my newb verdict...my ears aren't newb though!!!!
Thanks all and Happy New Year!!
BH
BH
