Anybody use a Stancor A-3801 type tranny in Tweed/Brown/Blackface type amp?
What were the results?
Re: Anybody use a Stancor A-3801 type tranny in Tweed/Brown/Blackface type amp?
It would be fine for a Tweed Fender with 6L6 outputs  , but for even  with just a Bkackface bandmaster or Proreverb it would be pushed too hard as even these amps with a good power supply and good strong output tubes can top 30 watts of RMS power and top 48 watts of peak power!
Hello -
Uncertain what is behind the question. That Stancor is rated 35W "HiFi" with 150mA DC spec'ed for the primary. Would do 40W handily in guitar amp. Higher-voltage EL34 Express clone is just that. Or better perhaps, use sale proceeds from your A-3801 to buy full set of iron to build whatever is desired, as ~$500 seems the listing price on Reverb?
Best .. Ian
Best .. Ian
The express's power transformer is rated for 300mA, whereas most fender PTs are rated at 200-240mA. I doubt that this will blow a A3801 but I have not tried it
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
- kanderson70
Been wondering the same only mine is a Pacific 11415 output. About to build a blackface tremolux and was wondering if it would work. Ended up buying a Classic Tone transformer just to be on the safe side.
The Pacific 11415 OT is 6k6 primary so if that is what you want in your tweed it sure can handle the power.
But I would choose the Magnetic Components transformer.
						- kanderson70
For tweed yes....but for blackface era Tremolux it calls for a 4k ohm secondary. Just was not sure if the 6.6k would work. I'll probably just stick with the Classic tone tranny.
For my brown faced Tremolux build I went with Weber PT W022798 and OT W022848 and Hammond choke 194B
Weber transformers aren't the best choice but I have had good track record since 2007 with these particular part numbers in about 4 different builds.
Normally ClassicTone or custom order Heyboer is my preferred choice. Mark
						- kanderson70
M Fowler wrote: ↑Fri Dec 07, 2018 1:57 pm For my brown faced Tremolux build I went with Weber PT W022798 and OT W022848 and Hammond choke 194B
Nice looking build Fowler!
I used a SE Stancor A-8092 in a vibrochamp build. Sounds awesome
