Hi All
What resistor brand inside the amp?
It very dark brown if compare with a general carbon film
Thank for any comment.
						What Brand Resistor?
				KrishnaphatM
						Re: What Brand Resistor?
Hi,
I see a picture of early versions of Pink Taco. If you look at the other photos of this amplifier, and other products Friedman, you can understand that this is the most common low-cost components. And the resistor is an ordinary carbon film
				KrishnaphatM
Ahhh....
In my country didn't have dark brown skin carbon film like Friedman or Two Rock
Thank for the comment
Has this amp anything to do with a Dumble?
The only brown resistors I see are on the left side of the pic. They state Ohmite and they are wire wound resistors.
KrishnaphatM wrote:Ahhh....
In the Friedman amps are used these resistors
https://www.tube-town.net/ttstore/Resis ... 3_349.html
				Charlie Wilson
This does not look like a Dumble circuit and should not be posted in this section.
CW
						CW
- pompeiisneaks
- Site Admin
Good point, moved to Technical Discussion.Charlie Wilson wrote: ↑Tue Nov 13, 2018 6:22 pm This does not look like a Dumble circuit and should not be posted in this section.
CW
The dark-brown 5w resistors are vitreous enamel.
