I think those values are more relevant to 5F6A based circuits, rather than 2 channel BF amps, whose NFB circuit resistances are much lower
NFB on multi-tap OT
pdf64
Re: NFB on multi-tap OT
yes, but it is the ratio that matters. the BF uses a 100R, not the 5k pots
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Absolutely, but I suspect that such a leap in circuit analysis may be lost on @espinete 's current level of understanding
For a blackface ab763 circuit (with a 100R NFB resistor in the phase inverter instead of the 5k presence pot), you can try a 470R resistor (instead of the 27k) and a 5k pot for variable NFB (instead of the 220k pot)
4x12" w/H75s
4x12" w/H75s
