Looking for some ideas...
				v00d00blues79
I have a 440-0-440v PT that has a 50v bias winding and a 6.3v tap.  I'm looking for some ideas to use this PT for.  I also have a OT that has a primary of 5k and UL taps.  Anyone have any suggestions on what i could build around this?
Thanks,
Andy
						Thanks,
Andy
				Billy Batz
- Funkalicousgroove
Re: Looking for some ideas...
I'd build something wuth KT88's, that tranny is going to give you +/- 560VDC on the plates, a 5K primary would work for 2 KT88's, perhaps a mini major??
				v00d00blues79
the tranny's are actually out of a SF Twin Reverb 135.  They are huge.  I'm thinking something like the KT-88 wouldn't be such a bad idea.  Finding a chassis that can hold these bad boys is going to be another thing all together.
Thanks!
Andy
						Thanks!
Andy
- Funkalicousgroove
I think I'd stay with stainless steel, you'd have to go to like .12 Aluminum for those big suckers!!
				v00d00blues79
I'm tossing around the idea right now of trying the front end of the RT66 with KT-88's in the output running UL with the voltage as close to 500v as i can get it.
Thanks,
Andy
						Thanks,
Andy
- Funkalicousgroove
THat's basically a blackface type curcuit isn't it?
				v00d00blues79
No, its an EF-86 front end driver with a VTB arrangement.  you can find the schem on acplink under dr z -> route 66.
Thanks,
andy
						Thanks,
andy
- Funkalicousgroove
that doesn't look like alot of fun  but I guess beauty is in the eye of the beholder!!  Good luck to ya!!
  but I guess beauty is in the eye of the beholder!!  Good luck to ya!!Owner/Solder Jockey Bludotone Amp Works
				v00d00blues79
doesn't look that bad... i did a CG clone not too long ago that was worse looking layout-wise, but turned out great.
Thanks,
Andy
						Thanks,
Andy
- Funkalicousgroove
Oh I'm sure it will be a fine amp, Loud and clean!  I've been throwing around the idea of building a UL amp myself, but I want to do something very out of the ordinary (Which the rt66 certainly is) but I played a DR.Z RT66 the other day and it sounded very "Dead" compared to his other stuff, it was just kind of vanilla.  Of course if there were one sound that suited everybody there would only be one kind of amp and we'd all have to find something else to occupy our time!  I'm interested to hear how it turns out!
				m.alexander
my friend DIY RT66 + mods (choke and moore ) the result is very cool!!!!v00d00blues79 wrote:No, its an EF-86 front end driver with a VTB arrangement. you can find the schem on acplink under dr z -> route 66.
Thanks,
andy
look this
Marks Amp
				v00d00blues79
Very Nice!!  Wonder if you'd be able to share the layout and chassis design with me?
Thanks,
Andy
						Thanks,
Andy
				m.alexander
e-mail for youv00d00blues79 wrote:Very Nice!! Wonder if you'd be able to share the layout and chassis design with me?
Thanks,
Andy
Marks Amp
Steel String Singer!!!
