dorrisant wrote: ↑Sat Mar 10, 2018 4:39 amPhil, I don't mean to pile on but the data sheets for a GZ34 rectifier, (used in a Rocket) spec 60µF max for the first filter...
Bear in mind that when tube info sheets were written, standard ecap value tolerance was as much as +100% to -50%.
The info notes 'input [ie reservoir] capacitor' not 'capacitance', so I suspect that the 60uF limit includes a bit of 'give' to account for the reservoir cap's actual value possibly being a bit above nominal.
Note that a very significant parameter mentioned in the info is the series / protecting resistance per plate, and for a given reservoir cap value, as the voltage increases (and hence the duration of time required to top up charge on the reservoir per half cycle), the value of the protecting resistance increases
http://www.mif.pg.gda.pl/homepages/fran ... g/GZ34.pdf
http://www.mif.pg.gda.pl/homepages/fran ... 5/5AR4.pdf
The protecting resistance is normally provided by the PT HT winding resistance, which means that the winding will necessarily have 'average to poor' regulation, and will get warm in operation.
I think an important consideration to take from that is if a 'cool running' PT with good regulation is used and no additional protecting resistors are added, then a smaller value of reservoir cap may be required to avoid breaching plate current limit.
dorrisant wrote: ↑Sat Mar 10, 2018 4:39 am...Ken used two 40µF caps in parallel for a total of 80µF as a reservoir. Try powering up without giving the rectifier a chance to get warmed up and fill the reservoir before supplying full load and you will see sparks after a short while. Not saying right away but I would bet money you will go through rectifier tubes much more often...
Rocket schematic
https://tubeamparchive.com/download/file.php?id=8003
Bear in mind that by design, the GZ34 has a slow warm up and its cathode voltage has a lovely smooth ramp up (my finding is that full HT is achieved about 45s after power up). That will naturally limit reservoir charging current, and by extension, the current that the power tubes can draw if powered up without standby, ie the power tubes can only draw 200mA at full HT.
At any lower point of the HT ramp up, the power tube current draw will be commensurately lower.
So I don't see how the use of standby takes any useful degree of stress off the GZ34 here? Rather the opposite, as the manufacturer's info emphasises the importance of limiting peak plate current.
To me, the important constraint with the Rocket and its 80uF reservoir, is that the PT has the intended degree of protecting resistance; I think that the standby   is purely a user convenience.
